Edit a Slot
Reposition, resize, or apply a sketch constraint to a slot.
Edit the slot:
To Do this Reposition a slot - Select the line and drag it, or
- Reposition the end points.
Adjust the length of a slot - Drag the point if there is no dimension, or
- Select the line, then enter a dimension to specify the length.
Adjust the width of a slot Select the end curve and then enter a dimension to specify the width, or drag the arc end point if there is no dimension for the width. Change the diameter Select the sketch curve, then enter a radius. Apply a sketch constraint Right-click a sketch curve, then select a sketch constraint on the context menu. Convert a sketch curve into construction geometry Right-click a sketch curve, then select Construction. Construction geometry is used as a reference to line up or define other geometry.
Hide dimensions Deselect Show dimensions in the Preferences. - Right-click and mouse through the check mark to exit, or double-right-click.
