Extend
Extend or shorten an entity of a sketch curve.
                Click the Extend icon.
 - Click an entity to select it.
                Move the mouse to preview the extended or shortened entity, and then click to
                    extend or shorten the entity.
                Tip: If in the previous step you selected an entity (A) that intersects with another entity (B), you can click B near the intersection point to extend or shorten A at that intersection point.
Table 1. Example 1: Extend Figure 1. Select Entity "A" (Line)
                                        Figure 2. Click Entity "B" (Arc) Near the Intersection Point
                                        Figure 3. "A" Is Extended to the Intersection Point
                                        Table 2. Example 2: Shorten Figure 4. Select Entity "A" (Line)
                                        Figure 5. Click Entity "B" (Arc) Near the Intersection Point
                                        Figure 6. "A" Is Shortened at the Intersection Point
Tip:
        - This tool does not currently work on Splines.
