Create/Edit Materials
Customize an existing material and add it to My Materials.
Click the View Materials button
on the nozzle microdialog.
- Select a Material Name from the Materials Database or My Materials tab on the Materials dialog.
Click the Edit button.
The editing operation moves you into the My Materials tab.
- Edit the material properties as required.
Enter a New Material Name at the bottom of the dialog
and click Save.
The new material is saved and is accessible from the My Materials tab for future use.
- Click the Select button to assign the new material to your model.
