Create a GCP Cloud Environment
Create a GCP cloud environment in NavOps so that workload manager execution nodes can be deployed in the cloud. Provide information about the cloud environment such as region, OS image, network name, subnet name and tags.
- Navigate to the NavOps browser window.
- Go to Clouds, and then select Environments.
- Click Add Environment.
- Click Select in the required Google credential tile.
- For Region, select the same geographic location as was selected for the previously created bursting VPC.
- For Environment Name, enter a name for the cloud environment.
- Navigate to the cloud provider browser window.
Click the navigation menu (
) located in the
upper left-hand corner of the web page.
- Click .
- Select the image created for cloud bursting.
- Click Equivalent REST
- Copy the value for the entry called selfLink.
- For OS Image, paste the link copied from GCP.
) located in the
- Click .
Click the name of the VPC that was created for cloud bursting.
VPC network details are displayed.
- Copy the name of the VPC network.
- For Network Name, paste the name of the VPC network copied from GCP.
- Copy the name of the VPC network subnet.
- For Subnet Name, paste the name of the VPC network subnet copied from GCP.
For Tags, enter a key-value pair to add a label to the
cloud node and press ENTER.
A tag is a label that is assigned to a cloud node. Tags enable cloud nodes to be categorized in different ways, for example, by purpose, owner, or environment.The key-value pair must be entered as key:value. The key must be less than 36 characters and the value must be less than 43 characters. The length of both the key + value should be less than 80 characters. Valid values are alphanumeric, dash (-) and an underscore ( _ ).Once the tag is added, it will appear within its own bubble.
Figure 1. Key-Value Tag
Repeat the previous step to add more tags.
Figure 2. Additional Tags
Tip: To remove a tag click on the 'x' located within the tag bubble. - Click Save to create the GCP Cloud Environment.
