Add a Microsoft Azure Credential
Add an Azure cloud account to NavOps so that you can create a cloud environment or an appliance.
- Application ID generated when registering NavOps with the Azure Active Directory.
- Client secret key generated for the newly registered NavOps application.
- Subscription ID
- Tenant ID
- Login to NavOps.
- Go to Clouds, and then select Credentials.
- Click Add Cloud Credentials
- Click Select in the Azure tile.
Enter the following to add a cloud credential:
- (Optional) For Tags, enter the suitable tags for the credentials.
- Click Test to check the credentials. If an error message is displayed, inspect the details from the Tasks list.
- Click Save.
