Material Library Overview
The material library contains preset materials, as well as any custom materials you've saved. Understand the material library's structure so you can more easily find materials.
Material Library Structure
- The Altair library contains preset materials.
- The User library contains any custom materials you've saved.
The material library is structured as follows:
For example:- Library name
- Altair
Resize the Thumbnails
Hover over the bottom of the dialog box to bring up the Preview size slider. Drag the slider to zoom in or out.
