Video Tutorial: Creating Field-Driven Effects in Lattices
A few videos showing you how to create field-driven effects in lattices using implicit geometry, implicit bodies, BRep or construction geometry, and point clouds.
This video shows you how to use implicit geometry and implicit bodies to create field-driven effects in lattices.
This video shows different ways in which you can use BRep or construction geometry to create field-driven effects in lattices.
This video shows a point cloud being created from simulation data, which is subsequently used to drive some lattice properties.
