Part
Define the constant heat source for the thermal power generated by the solid part.
On the Fluids ribbon, select the Part tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select one or more solid parts.
In the microdialog, define the Heat source:
- Per Unit Volume
- Per Unit Mass
- Total Power
- Based on the unit you selected, follow the relevant steps below.
- Optional:
If desired, you can click the
button to create a variable, or use an existing variable, for the part
condition.
Per Unit Volume
Specify the constant heat source by the thermal power per unit volume.
In the microdialog, enter a value to define the constant heat source
Per Unit Volume.
The selected parts will produce the specified amount of heat during the simulation.
Per Unit Mass
Specify the constant heat source by the thermal power per unit mass.
Per Unit Mass.
Total Power
Specify the constant heat source by the total thermal power.
In the microdialog, enter a value to define the constant heat source for
Total Thermal Power.
