Internal Forces Computation
Nodes are numbered from 1 to n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ , and strands are numbered from 1 to n-1 (strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ goes from node Nk to node Nk+1).
Averaged Force
The averaged force in the multistrand is computed as:
Linear spring F = K L 0 δ + C L 0 δ ˙
Nonlinear spring F = f ( ε ) ⋅ g ( ε ˙ ) + C L 0 δ ˙
or, if g function identifier is 0:
F = f ( ε ) + C L 0 δ ˙
or, if f function identifier is 0:
F = g ( ε ˙ ) + C L 0 δ ˙
Where, ε is engineering strain ε = L − L 0 L 0 .
Where, L 0 is the reference length of element.
Force Into Each Strand
The force into each strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ is computed as:
F k = F + Δ F k
Where, Δ F k is computed an incremental way:
Δ F k ( t ) = Δ F k ( t − 1 ) + K l k 0 δ ε k − K L 0 δ ε
with l k 0 the length of the unconstrained strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ , δ ε = ε ( t ) − ε ( t − 1 ) and δ ε k = δ t u k ⋅ ( v k + 1 − v k ) .
Where, u k is the unitary vector from node Nk to node Nk+1.
Assuming:
l k l k 0 = L L 0
Where, l k is the actual length of strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ .
Therefore, Equation 3 reduces to:
Δ F k ( t )=Δ F k ( t−1 )+ K l 0 ( δ ε k L l k −δε )
Friction
Friction is expressed at the nodes: if μ is the friction coefficient at node k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ , the pulley friction at node Nk is expressed as:
When equation Equation 6 is not satisfied, | Δ F k − 1 − Δ F k | is reset to ( 2 F + Δ F k − 1 + Δ F k ) tanh ( β μ 2 ) .
All the Δ F k (k=1, n-1) are modified in order to satisfy all conditions upon Δ F k − 1 − Δ F k (k=2, n-1), plus the following condition on the force integral along the multistrand element:
∑ k = 1 , n − 1 l k ( F + Δ F k ) = L F
This process could fail to satisfy Equation 6 after the Δ F k ( k = 1 , n − 1 ) modification, since no iteration is made. However, in such a case one would expect the friction condition to be satisfied after a few time steps.
Note: Friction expressed upon strands (giving a friction coefficient μ along strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ ) is related to pulley friction by adding a friction coefficient μ / 2 upon each nodes Nk and Nk+1.
Time Step
Stability of a multistrand element is expressed as:
Δ t ≤ C k 2 + ρ l k K k − C k K k , ∀ k
with K k = M a s s   o f   t h e   m u l t i s t r a n d L 0 and (assuming Equation 4):
K k = max ( K l k 0 , F l k − l k 0 ) = max ( K L l k L 0 , F L l k ( L − L 0 ) )
C k = ( f ( ε ) d g d ε ˙ ( ε ˙ ) + C ) l k 0 = ( f ( ε ) d g d ε ( ε ˙ ) + C ) L l k L 0
