/SECT
Block Format Keyword Sections are used to output the force and moment of a cross section defined by a group of nodes and groups of elements.
Section data saved in one simulation can be read and applied in a second simulation.
/SECT/sect_ID/unit_ID
sect_title
node_ID1 node_ID2 node_ID3 grnd_ID ISAVE frame_ID Δ t α
file_name
grbric_ID grshel_ID grtrus_ID grbeam_ID grsprg_ID grtria_ID Ninter Iframe
Input read only if Ninter > 0
int_ID1 int_ID2 int_ID3 int_ID4 int_ID5 int_ID6 int_ID7 int_ID8 int_ID9 int_ID10
Definition
sect_ID Section identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
sect_title Section title.
node_ID1 Node identifier N1 defining the local output system of the section. 2
(Integer)
node_ID2 Node identifier N2 defining the local output system of the section. 2
(Integer)
node_ID3 Node identifier N3 defining the local output system of the section. 2
(Integer)
grnd_ID Node group identifier which defines the nodes used in the section calculation.
Not used if frame_ID is defined.
(Integer)
ISAVE Saving or reading the section data from file_name flag.
=0
Do not save any data.
=1
Save section displacements in the section cut file.
=2
Save section displacements, resultant force, and moment components in the section cut file.
=100
Read and apply the section data as loads to the model.
=101
Also output in the time history the difference between the applied section resultants (force and moment) and the simulation’s calculated section results. This option requires that the section data was created using the ISAVE =2 option.
(Integer)
frame_ID (Optional) Moving frame identifier. Must be defined using nodes /FRAME/MOV. The xy plane of the frame intersects the elements groups to automatically define the nodes and elements used in the section calculation. If node_ID1 - node_ID3 are not defined then the frame is also used as the output system of the section.
(Integer)
Δ t Time step for saving the section data used with ISAVE =1 or 2.
Default = time step of the simulation (Real)
[ s ]
α Exponential moving average filtering constant (0 < α < 1). Smaller values result in more filtering
Only used when applying the displacements to a section using ISAVE= 100 or 101.
Recommended value = 0.62832 (refer to Filter in the User Guide)
Default = No filtering (Real)
file_name Root name of the file which contains the flag output. The section file will be named file_nameSC01.
Default = Runname (where Runname is the prefix to the Engine file, Runname_0001.rad)
grbric_ID Brick group identifier.
(Integer)
grshel_ID Shell group identifier.
(Integer)
grtrus_ID Truss group identifier.
(Integer)
grbeam_ID Beam group identifier.
(Integer)
grsprg_ID Spring group identifier.
(Integer)
grtria_ID Triangle group identifier.
(Integer)
Ninter (Optional) Number of interfaces.
Default = 0 (Integer)
Iframe Flag defining the center of the local system used in the calculation of the section forces and moments. 3
The section output is in the local system with the center defined as:
=0
Origin of the local section system.
=1
Geometrical center of the section.
=2
CoG of the section.
=3
Center is the global system point.
The section output is in the global system with the center defined as:
=10
Origin of the global local section system.
=11
=12
CoG of the section.
=13
Center is the global system point (0,0,0).
(Integer)
int_ID1, int_ID2, ..., int_IDn Optional interface identifiers, if Ninter > 0.
(Integer)
  1. A section is defined by a node group and element groups and can be defined manually or automatically.
    • Manually:
      The section nodes (grnd_ID and elements (grbric_ID, grshel_ID, grtrus_ID, ...) are user-defined. HyperMesh will automatically create the groups but, they should be reviewed. Using this method, the user creates the node and element groups that define the section cut. Typically, nodes in the normal direction of the section are used in the node group.
      Figure 1. Elements and Nodes Selected Manually
    • Automatic:
      A local system frame_ID can be defined which cuts the defined groups of elements (grbric_ID, grshel_ID, grtrus_ID, ...). In this case, the element groups contain all the elements in the area of the section. The nodes and elements on the xy plane of the local system are automatically defined for the section calculation. The nodes and elements used in the section are then output in the Starter output file. The cutting plane is the xy plane of the system.
      Figure 2. Element Group (in orange) defined for a section cut defined using a local system
      If no elements from the element groups are cut by the xy-plane of frame_ID, then the section will be empty.
  2. The forces and moments from the sections will be stored in the time history file and requested using /TH/SECTIO.
  3. The local force and moment output system of the section is defined using 3 nodes or via a local moving system (frame_ID). These three nodes should be nodes on the section plane, so their position is updated when the section moves. When using the Cross-Section Assistant in HyperMesh to create the section, the 3 nodes are automatically selected. When defined using node_ID1 - node_ID3, the definition using nodes:
    • Nodes node_ID1 and node_ID2 define the local x-axis of the section.
    • Nodes node_ID1, node_ID2, and node_ID3 define the local plane xy of the section.
    • The local y-axis is defined by projecting node_ID3 perpendicular to the local x-axis.
    • The intersection of the local x- and y-axis is then the origin of the system.
    • Last the section normal is the local z-axis which is perpendicular to the xy plane:
      Figure 3.
    • If frame_ID ≠ 0 and node_ID1-node_ID3 are not defined, then the moving frame_ID is used as the local system. The frame should be a moving frame defined using nodes.
    • The center of the section can be redefined using the Iframe option. Refer to Force and Moment Computation in the User Guide for more details.
  4. Sections can also be used in a cut modeling method where section forces and displacements are saved from a full model and then applied in a second cut model. In the full model, the section information is saved using the ISAVE =1 or 2 option. Then in the cut model, the same section nodes and element groups are defined and the section displacements are applied to the cut model using ISAVE =100 or 101. The cut model is then used to study a detailed area of the full model (RD-E: 5400 Cut Methodology).
  5. Recommendations:
    Pick nodes and elements along the section. If nodes and elements are automatically selected by a preprocessor review what was selected.
    Select the 3 nodes for node_ID1-node_ID3 that are defined in the node group.
    Define Iframe =2 or 12, the center is the CoG of the section.
    Time history output GLOBAL and LOCAL in /TH/SECTIO.
