/MPC
Block Format Keyword Defines multi-point constraints on nodes.
/MPC/MPC_ID
MPC_title
Card 1 to N
node_ID1 Idof1 skew_ID1 α 1
node_ID2 Idof2 skew_ID2 α 2
etc etc etc etc
node_IDN IdofN skew_IDN α N
Definition
MPC_ID Multi-point constraint identifier.
(Integer, maximum 10 digits)
MPC_title Multi-point constraint title.
node_IDi Node identifier.
(Integer)
Idofi Degree-of-freedom (velocity direction).
(Integer)
skew_IDi Local skew (for each DOF).
(Integer)
α i Scale coefficient.
(Real)
  1. This option is not available if it is applied on:
    • a translational DOF of a node with a null mass
    • a rotational DOF of a node with a null inertia
  2. User-defined linear relation between nodal velocities.
  3. The N formats are necessary to define a kinematic relation between N velocity components. Each term may be expressed in its own local skew system (Skew_ID):(1)
    i = 1 N α V i d o f i s k ( n o d e ) = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaabCaeaacq aHXoqycqGHflY1caWGwbWaa0baaSqaaiaadMgacaWGKbGaam4Baiaa dAgaaeaacaWGPbGaam4CaiaadUgaaaGccaGGOaGaamOBaiaad+gaca WGKbGaamyzaiaacMcacqGH9aqpcaaIWaaaleaacaWGPbGaeyypa0Ja aGymaaqaaiaad6eaa0GaeyyeIuoaaaa@4E15@
    i s k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiaado hacaWGRbaaaa@38CC@ = Skew_ID
    idof MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiaads gacaWGVbGaamOzaaaa@39AC@ = 1...6
    1...3: translational velocity
    4...6: rotational velocity
