Gear type joints are more complex than other kinematic joints. They use the
Lagrange Multiplier method and are compatible with all other Lagrange Multiplier
kinematic conditions and incompatible with all classical kinematic
conditions.
Three examples of these joints are explained:
Rotational gear type joint
Rack and pinion joint
Differential gear joint
Mass and inertia may be added to all nodes. MPC joints impose relations between nodes velocities. The MPC cannot be applied to the translational degrees of freedom of a node without mass or the rotational degrees of freedom of a node without inertia.
Rotational Gear Type Joint
This joint is used to impose a rotational velocity relation between input and output node as:
Translational velocities of gear joint nodes are constrained by a rigid link relation. For the
rotational degrees of freedom, a scale factor is imposed between
velocities of nodes N1 and
N2, measured in their local
coordinates. The corresponding constraint equations
are:
Where, are relative rotational
N2 in respect of the rigid
body rotational velocity.
Rack and Pinion Joint
This joint allows the rotational velocity of node to be transformed to a translational velocity
as:
The constraint equations for these velocities are:
Differential Gear Joint
This joint is used to impose rotational velocity relations between an input node and two output
nodes as:
The rotational velocities of a differential gear joint are constrained by the
relations:
