/INCLUDE_LS-DYNA
Block Format Keyword Option to include LS-DYNA format file in the Radioss Starter input (Runname_0000.rad) file.
/INCLUDE_LS-DYNA
filename
Definition
filename Filename and path of the include LS-DYNA file in the Radioss Starter input deck.
(Character)
  1. The include filename must be in LS-DYNA Input format.
  2. The model can only contain one single card /INCLUDE_LS-DYNA with one include file. However, several include files can be defined within the LS-DYNA model.
  3. The LS-DYNA model must not contain the *INCLUDE_RADIOSS card.
