This law is a constitutive model for predicting the nonlinear time dependency of
elastomer like materials. It uses a polynomial material model for the hyperelastic material
response and the Bergstrom-Boyce material model to represent the nonlinear viscoelastic time
dependent material response.
This law is only compatible with solid elements.
The response of the material can be represented using two parallel networks A and B.
Network A is the equilibrium network with a nonlinear hyperelastic component. In
Network B, a nonlinear hyperelastic component is in series with a nonlinear
viscoelastic flow element, and hence, is time-dependent network.
Figure 1 .
Material Parameters
The same polynomial strain energy density formulation is used for the hyperelastic
components in both networks. In Network B, it is scaled by a factor
S
b
MathType@MTEF@5@5@+=
feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGtbWaaS
baaSqaaiaadkgaaeqaaaaa@384A@
. The strain energy density is then written for the
hyperelastic component of the network.
and
Where,
I
1
λ
1
2
λ
2
2
λ
3
2
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWGjbGbae
badaWgaaWcbaGaaGymaaqabaGccqGH9aqpcuaH7oaBgaqeamaaDaaa
leaacaaIXaaabaGaaGOmaaaakiabgUcaRiqbeU7aSzaaraWaa0baaS
qaaiaaikdaaeaacaaIYaaaaOGaey4kaSIafq4UdWMbaebadaqhaaWc
baGaaG4maaqaaiaaikdaaaaaaa@4567@
I
2
λ
1
2
λ
2
2
λ
3
2
badaWgaaWcbaGaaGOmaaqabaGccqGH9aqpcuaH7oaBgaqeamaaDaaa
leaacaaIXaaabaGaeyOeI0IaaGOmaaaakiabgUcaRiqbeU7aSzaara
Waa0baaSqaaiaaikdaaeaacqGHsislcaaIYaaaaOGaey4kaSIafq4U
dWMbaebadaqhaaWcbaGaaG4maaqaaiabgkHiTiaaikdaaaaaaa@482F@
λ
i
J
1
3
λ
i
vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4UdWMbae
badaWgaaWcbaGaamyAaaqabaGccqGH9aqpcaWGkbWaaWbaaSqabeaa
cqGHsisldaWcaaqaaiaaigdaaeaacaaIZaaaaaaakiabeU7aSnaaBa
aaleaacaWGPbaabeaaaaa@4036@
C
i
j
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaS
baaSqaaiaadMgacaWGQbaabeaaaaa@3930@
and
D
i
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebWaaS
baaSqaaiaadMgaaeqaaaaa@3842@
Material parameters
The hyperelastic component the Cauchy stress is computed as:
The total stress is the summer of stress in network A and network B.
Figure 2 .
σ =
σ
A
σ
B
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4WdmNaey
ypa0Jafq4WdmNbaebadaWgaaWcbaGaamyqaaqabaGccqGHRaWkcuaH
dpWCgaqeamaaBaaaleaacaWGcbaabeaaaaa@3F47@
Since
W
B
S
b
W
A
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS
baaSqaaiaadkeaaeqaaOGaeyypa0Jaam4uamaaBaaaleaacaWGIbaa
beaakiabgwSixlaadEfadaWgaaWcbaGaamyqaaqabaaaaa@3F4B@
, then
σ
B
S
b
σ
A
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae
badaWgaaWcbaGaamOqaaqabaGccqGH9aqpcaWGtbWaaSbaaSqaaiaa
dkgaaeqaaOGaeyyXICTafq4WdmNbaebadaWgaaWcbaGaamyqaaqaba
aaaa@40E1@
and total stress is
σ
1
S
b
σ
A
ypa0JaaiikaiaaigdacqGHRaWkcaWGtbWaaSbaaSqaaiaadkgaaeqa
aOGaaiykaiabgwSixlqbeo8aZzaaraWaaSbaaSqaaiaadgeaaeqaaa aa@42C2@
For example, in one tensile test. If use
S
b
2
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa
aaleaacaWGIbaabeaakiabg2da9iaaikdaaaa@39AE@
, the stress is 3 times of the one without
considering viscous (which means only considered hyperelastic).
Figure 3 .
For special values of
C
i
j
, the polynomial model can be reduced to the
following material models.
Yeoh:
j
0
feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOAaiabg2
da9iaaicdaaaa@38A5@
Where,
C
10
C
20
C
30
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa
aaleaacaaIXaGaaGimaaqabaGccaGGSaGaam4qamaaBaaaleaacaaI
YaGaaGimaaqabaGccaGGSaGaam4qamaaBaaaleaacaaIZaGaaGimaa
qabaaaaa@3EA8@
are not zero.
Figure 4 .
Mooney-Rivlin:
i
j
1
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaiabgU
caRiaadQgacqGH9aqpcaaIXaaaaa@3A76@
Where,
C
10
qabaaaaa@3EA8@
and
C
01
qabaaaaa@3EA8@
are not zero and
D
2
D
3
0
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa
aaleaacaaIYaaabeaakiabg2da9iaadseadaWgaaWcbaGaaG4maaqa
baGccqGH9aqpcaaIWaaaaa@3C33@
Neo-Hookean: Only
C
10
qabaaaaa@3EA8@
and
D
1
aaleaacaaIXaaabeaaaaa@37A6@
are not zero.
Where,
C
i
j
and
D
i
Material parameters which can be calculated by completing a curve fit
for quasi-static material test data.
RD-E: 5600 Hyperelastic Material with Curve Input , contains a
curve fit example for Mooney-Rivlin and Yeoh material models.
D
1
can be calculated from the bulk modulus or left
blank.
The initial shear modulus and the bulk modulus are computed as:
and
If the bulk modulus of the material is known,
D
1
can be calculated, or if
D
1
=0, an incompressible material is assumed.
Viscous (Rate) Effects
The effective creep strain rate in Network B is given by:
Where,
λ
I
1
3
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacuaH7oaBga
acaiabg2da9maakaaabaWaaSaaaeaaceWGjbGbaebadaWgaaWcbaGa
aGymaaqabaaakeaacaaIZaaaaaWcbeaaaaa@3BE7@
σ
B
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacuaHdpWCga
qeamaaBaaaleaacaWGcbaabeaaaaa@392D@
Effective stress in Network B.
A
ξ
M
C
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbGaai
ilaiaaysW7cqaH+oaEcaGGSaGaaGjbVlaad2eacaGGSaGaaGjbVlaa
doeaaaa@4139@
, and
τ
r
e
f
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHepaDda
WgaaWcbaGaamOCaiaadwgacaWGMbaabeaaaaa@3B1C@
Input material parameters.
The material constants
A
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqaaaa@36BC@
M
and
C
are limited to a specific range of real values as
defined in the Reference Guide . If limited data is available, a trial
and error method 1 could be used to determine these
constants. Start with the default values of
ξ
M
C
doeaaaa@4139@
S
b
=1.6; and
A
=5. Next, compare model predictions with experimental
data for at least one strain rate and adjust
A
to get a fit for the strain rate data.
