COMMU1
This option is used to simulate chambered airbags and may be used to unfold an airbag.
Each COMMU1 type monitored volume works like an AIRBAG1 type monitored volume with possible vent communication with some other COMMU1 type monitored volume. A chambered airbag is therefore designed with two or more COMMU1 type monitored volumes.
Each monitored volume can have an inflator and vent holes.
Case 1: Folded Airbag
- Volume 1: Prop. 1 + 4 + 5
- Communication area: vol. 1 to 2: prop. 4
- Volume 2: Prop. 2 + 4
- Communication area: vol. 2 to 1: prop. 4
- Volume 3: Prop. 3 + 5
- Communication area: vol. 3 to 1: prop. 5
Case 2: General Use
Monitored volume 1 can communicate with monitored volume 2 with or without communication from 2 to 1. Communication area, deflation pressure or time from 1 to 2 can be different than corresponding values from 2 to 1. That way it is possible to model a valve communication.
Two communication monitored volumes can have common nodes or common shell property set, but this is optional.
General Equations
Same equations for AIRBAG1 type monitored volume are used, but incoming and outgoing enthalpy and kinetic energies will take into account the communicating bags. For each communicating volume for which pressure is lower than in current volume, a mass and energy flow is computed with same equations for vent holes, the external pressure is just replaced by the pressure of communicating volume:
These mass and energy fluxes are removed from current volume and added to communicating volume at the next cycle.
Inflator, Vent Hole, Initial Conditions
Inflator, atmospheric vent holes and initial conditions are identical to /MONVOL/AIRBAG1 type monitored volume.
Specific Input
- Viscosity factor
- External pressure
- Relative vent deflation pressure
- Avent
- Vent area ( ) or discharge factor ( )
- Tstart
- Time to deflate vent hole
Initial gas and injected gas defined with /MAT/GAS.
- fct_IDM
- Injected mass curve (or mass rate)
- FscaleM
- Scale factor for injected mass curve (or mass rate)
- fct_IDT
- Injected temperature curve
- FscaleT
- Scale factor for injected temperature curve
- sens_ID
- Sensor number to start injection
- Nvent
- Number of vent hole
- Nbag
- Number of communicating volume
- bag_ID
- Identification of communicating volume
- Defines the communication area
- Relative communication deflation pressure
- Acom
- Communication area ( ) or discharge factor ( )
- Tcom
- Time to deflate communication area
In volume j input, the data for communication with volume k concerns only the flow from j to k. The data concerning the flow from k to j is defined in volume k input.
