Uniform pressure is assumed inside the volume. Perfect gas law and adiabatic conditions are
assumed. Injected mass (or mass flow rate) and temperature are defined as a time
function using the injector property. A sensor can define the inflator starting
time.
The deflation of the vent hole occurs after reaching a pressure (
P
d
e
f
MathType@MTEF@5@5@+=
feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG0bWaaS
baaSqaaiaadsgacaWGLbGaamOzaaqabaaaaa@3A42@
) or time (
t
d
e
f
) criteria.
Numerical Damping
Viscosity,
μ
can be used to reduce numerical oscillations.
If
μ
=1, a critical damping (shell mass and volume stiffness) is
used. A viscous pressure,
q
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGXbaaaa@3755@
is computed as:
q
μ
A
P
A
ρ
t
V
d
V
d
t
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGXbGaey
ypa0JaeyOeI0YaaSaaaeaacqaH8oqBaeaacaWGbbaaamaakaaabaWa
aSaaaeaacaWGqbGaamyqaiabeg8aYjaadshaaeaacaWGwbaaaaWcbe
aakmaalaaabaGaamizaiaadAfaaeaacaWGKbGaamiDaaaaaaa@44EE@
if
d
V
d
t
0
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWcaaqaai
aadsgacaWGwbaabaGaamizaiaadshaaaGaeyipaWJaaGimaaaa@3BD3@
q
0
ypa0JaaGimaaaa@3915@
if
d V
d t
> 0
aadsgacaWGwbaabaGaamizaiaadshaaaGaeyOpa4JaaGimaaaa@3BD7@
Where,
t
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG0baaaa@3758@
Fabric thickness
ρ
Density of the fabric
A
Bag surface
The applied pressure is:
(1)
P
P
e
x
t
q
Initial Conditions
To avoid initial disequilibrium and mathematical discontinuity for zero mass or zero volume, the
following initial conditions are set at time zero (I equil =0) or at the beginning of jetting (if I equil =1).
P
e
x
t
P
i
n
i
feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa
aaleaacaWGLbGaamiEaiaadshaaeqaaOGaeyypa0JaamiuamaaBaaa
leaacaWGPbGaamOBaiaadMgaaeqaaaaa@3EB7@
external pressure
T
0
T
i
n
i
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaaBa
aaleaacaaIWaaabeaakiabg2da9iaadsfadaWgaaWcbaGaamyAaiaa
d6gacaWGPbaabeaaaaa@3C99@
initial temperature (295K by default)
If the initial volume is less than
10
4
A
3
2
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaaIXaGaaG
imamaaCaaaleqabaGaeyOeI0IaaGinaaaakiaadgeadaahaaWcbeqa
amaaliaabaGaaG4maaqaaiaaikdaaaaaaaaa@3C34@
, a constant small volume is added to obtain an
initial volume:
V
i
n
i
10
4
A
3
2
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGwbWaaS
baaSqaaiaadMgacaWGUbGaamyAaaqabaGccqGH9aqpcaaIXaGaaGim
amaaCaaaleqabaGaeyOeI0IaaGinaaaakiaadgeadaahaaWcbeqaam
aaliaabaGaaG4maaqaaiaaikdaaaaaaaaa@411A@
Initial mass, energy and density are defined from the above values.
There is no need to define an injected mass at time zero.
Gases Definition
Initial and injected gas is defined with /MAT/GAS . Four types
of gas (MASS, MOLE, PREDEF, or CSTA) could be defined. Then the specific
capacity per unit mass at constant pressure for the gas is:
MASS type(2)
C
p
C
p
a
C
p
b
T
C
p
c
T
2
C
p
d
T
3
C
p
e
T
2
C
p
f
T
4
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaS
baaSqaaiaadchaaeqaaOGaeyypa0ZaaeWaceaacaWGdbWaaSbaaSqa
aiaadchacaWGHbaabeaakiabgUcaRiaadoeadaWgaaWcbaGaamiCai
aadkgaaeqaaOGaaGjbVlaadsfacqGHRaWkcaWGdbWaaSbaaSqaaiaa
dchacaWGJbaabeaakiaaysW7caWGubWaaWbaaSqabeaacaaIYaaaaO
Gaey4kaSIaam4qamaaBaaaleaacaWGWbGaamizaaqabaGccaaMe8Ua
amivamaaCaaaleqabaGaaG4maaaakiabgUcaRmaalaaabaGaam4qam
aaBaaaleaacaWGWbGaamyzaaqabaaakeaacaWGubWaaWbaaSqabeaa
caaIYaaaaaaakiabgUcaRiaadoeadaWgaaWcbaGaamiCaiaadAgaae
qaaOGaaGjbVlaadsfadaahaaWcbeqaaiaaisdaaaaakiaawIcacaGL
Paaaaaa@5EC1@
MOLE type(3)
C
p
1
M
W
C
p
a
C
p
b
T
C
p
c
T
2
C
p
d
T
3
C
p
e
T
2
baaSqaaiaadchaaeqaaOGaeyypa0ZaaSaaaeaacaaIXaaabaGaamyt
aiaadEfaaaWaaeWaceaacaWGdbWaaSbaaSqaaiaadchacaWGHbaabe
aakiabgUcaRiaadoeadaWgaaWcbaGaamiCaiaadkgaaeqaaOGaaGjb
VlaadsfacqGHRaWkcaWGdbWaaSbaaSqaaiaadchacaWGJbaabeaaki
aaysW7caWGubWaaWbaaSqabeaacaaIYaaaaOGaey4kaSIaam4qamaa
BaaaleaacaWGWbGaamizaaqabaGccaaMe8UaamivamaaCaaaleqaba
GaaG4maaaakiabgUcaRmaalaaabaGaam4qamaaBaaaleaacaWGWbGa
amyzaaqabaaakeaacaWGubWaaWbaaSqabeaacaaIYaaaaaaaaOGaay
jkaiaawMcaaaaa@5A1F@
Where,
M
W
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbGaam
4vaaaa@380C@
is the molecular weight of the
gas.
CSTA typeUser input
C
p
baaSqaaiaadchaaeqaaaaa@3847@
and
C
V
with the unit of
J
k
g
K
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWadaqaam
aalaaabaGaamOsaaqaaiaadUgacaWGNbGaam4saaaaaiaawUfacaGL
Dbaaaaa@3BDB@
PREDEF typeAbout 14 commonly used gases (N2, O2, Air, and so on)
predefined in Radioss .
Injected gasN jet defines the
number of injectors by monitored volume. The material of the injected gas is
defined with /MAT/GAS . The injector properties
(/PROP/INJECT1 or /PROP/INJECT2 )
define the injected mass curve defined
fct_ID M and
injected temperature curve defined
fct_ID T .
Injected
mass curve and injection temperature can be obtained:
From the airbag manufacturer
From a tank test
sens_ID is the sensor number to start injection.
Jetting effect I jet is used
only for /MONVOL/AIRBAG1 or
/MONVOL/COMMU1 If
I jet ≠ 0, the
jetting effect is modeled as an overpressure
Δ
P
j
e
t
applied to elements of the
bag.
(4)
Δ
P
j
e
t
Δ
P
t
Δ
P
θ
Δ
P
δ
max
n
m
0
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca
WGqbWaaSbaaSqaaiaadQgacaWGLbGaamiDaaqabaGccqGH9aqpcqqH
uoarciGGqbWaaeWaaeaacaWG0baacaGLOaGaayzkaaGaeyyXICTaeu
iLdqKaciiuamaabmaabaGaeqiUdehacaGLOaGaayzkaaGaeyyXICTa
euiLdqKaciiuamaabmaabaGaeqiTdqgacaGLOaGaayzkaaGaeyyXIC
TaciyBaiaacggacaGG4bWaaeWaaeaacaWHUbGaeS4JPFMaaCyBaiaa
cYcacaaIWaaacaGLOaGaayzkaaaaaa@5D4D@
N1 , N2 , and N3 are defined
based on the injector geometry (refer to the Radioss Starter Input Manual )
Δ
P
t
Δ
P
θ
Δ
P
δ
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarci
GGqbWaaeWaaeaacaWG0baacaGLOaGaayzkaaGaaiilaiabfs5aejGa
ccfadaqadaqaaiabeI7aXbGaayjkaiaawMcaaiaacYcacqqHuoarci
GGqbWaaeWaaeaacqaH0oazaiaawIcacaGLPaaaaaa@4762@
are empirical functions provided by the user
via
f
c
t
_
I
D
P
t
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam
4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamiuaiaadsha
aeqaaaaa@3D9F@
f
c
t
_
I
D
P
θ
4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamiuaiabeI7a
Xbqabaaaaa@3E5C@
, and
f
c
t
_
I
D
P
δ
4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamiuaiabes7a
Kbqabaaaaa@3E4B@
Vent Hole Definition
N vent
defines the number of vent holes used
s
u
r
f
_
I
D
v
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGZbGaam
yDaiaadkhacaWGMbGaai4xaiaadMeacaWGebWaaSbaaSqaaiaadAha
aeqaaaaa@3DD4@
surface identifier defining the vent hole
A vent
vent area (if
s
u
r
f
_
I
D
v
0
aeqaaOGaeyypa0JaaGimaaaa@3F9E@
) or a scale factor (
s
u
r
f
_
I
D
v
aeqaaaaa@3DD4@
≠ 0)
B vent = 0 (if
s
u
r
f
_
I
D
v
0
) or a scale factor on the impacted surface (
s
u
r
f
_
I
D
v
aeqaaaaa@3DD4@
≠ 0)
T stop
stop time for venting
T start
time at which leakage starts
Δ
P
d
e
f
relative vent deflation pressure
Δ
t
P
d
e
f
WG0bGaamiuamaaBaaaleaacaWGKbGaamyzaiaadAgaaeqaaaaa@3C7D@
Time duration during which
Δ
P
Δ
P
d
e
f
f
c
t
_
I
D
v
4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamODaaqabaaa
aa@3CCC@
Function identifier
f
P
P
P
e
x
t
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaaS
baaSqaaiaadcfaaeqaaOWaaeWaaeaacaWGqbGaeyOeI0Iaamiuamaa
BaaaleaacaWGLbGaamiEaiaadshaaeqaaaGccaGLOaGaayzkaaaaaa@3F8C@
for Chemkin model (I form =2)
(5)
v
e
n
t
_
h
o
l
e
s
_
s
u
r
f
a
c
e
A
v
e
n
t
A
n
o
n
_
i
m
p
a
c
t
e
d
f
t
t
f
P
P
P
e
x
t
f
A
A
n
o
n
_
i
m
p
a
c
t
e
d
A
0
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa
WdbiaadAhacaWGLbGaamOBaiaadshacaGGFbGaamiAaiaad+gacaWG
SbGaamyzaiaadohacaGGFbGaam4CaiaadwhacaWGYbGaamOzaiaadg
gacaWGJbGaamyzaiaabccacqGH9aqppaGaamyqamaaBaaaleaacaWG
2bGaamyzaiaad6gacaWG0baabeaakiabgwSixlaadgeadaWgaaWcba
GaamOBaiaad+gacaWGUbGaai4xaiaadMgacaWGTbGaamiCaiaadgga
caWGJbGaamiDaiaadwgacaWGKbaabeaakiabgwSixlGacAgadaWgaa
WcbaGaamiDaaqabaGcdaqadaqaaiaadshaaiaawIcacaGLPaaacqGH
flY1ciGGMbWaaSbaaSqaaiaadcfaaeqaaOWaaeWaaeaacaWGqbGaey
OeI0IaamiuamaaBaaaleaacaWGLbGaamiEaiaadshaaeqaaaGccaGL
OaGaayzkaaGaeyyXICTaciOzamaaBaaaleaacaWGbbaabeaakmaabm
aabaWaaSaaaeaacaWGbbWaaSbaaSqaaiaad6gacaWGVbGaamOBaiaa
c+facaWGPbGaamyBaiaadchacaWGHbGaam4yaiaadshacaWGLbGaam
izaaqabaaakeaacaWGbbWaaSbaaSqaaiaaicdaaeqaaaaaaOGaayjk
aiaawMcaaaaa@8254@
If
f
c
t
_
I
D
v
0
4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamODaaqabaGc
cqGHGjsUcaaIWaaaaa@3F57@
, the outflow velocity,
v
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaaleaacaWG2baaaa@375B@
is defined by Chemkin
as:
(6)
v
F
s
c
a
l
e
v
f
v
P
P
e
x
t
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG2bGaey
ypa0JaamOraiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqa
aiaadAhaaeqaaOGaciOzamaaBaaaleaacaWG2baabeaakmaabmaaba
GaamiuaiabgkHiTiaadcfadaWgaaWcbaGaamyzaiaadIhacaWG0baa
beaaaOGaayjkaiaawMcaaaaa@4850@
Where,
F
s
c
a
l
e
v
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaam
4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamODaaqabaaa aa@3CF2@
is the scale factor of the function
f
c
t
_
I
D
v
4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamODaaqabaaa aa@3CCC@
and the outgoing mass is computed as:
(7)
m
o u t
= ρ ⋅
A
v e n t
f
v
P −
P
e x t
) ⋅ F s c a l
e
v
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWGTbGbai
aadaWgaaWcbaGaam4BaiaadwhacaWG0baabeaakiabg2da9iabeg8a
YjabgwSixlaadgeadaWgaaWcbaGaamODaiaadwgacaWGUbGaamiDaa
qabaGccqGHflY1ciGGMbWaaSbaaSqaaiaadAhaaeqaaOWaaeWaaeaa
caWGqbGaeyOeI0IaamiuamaaBaaaleaacaWGLbGaamiEaiaadshaae
qaaaGccaGLOaGaayzkaaGaeyyXICTaamOraiaadohacaWGJbGaamyy
aiaadYgacaWGLbWaaSbaaSqaaiaadAhaaeqaaaaa@58CE@
Or, with the conservation of enthalpy between airbag and vent hole, adiabatic
conditions and unshocked flow, it is then possible to express outgoing mass flow
through vent holes as a function of
P
e
x
t
aaleaacaWGLbGaamiEaiaadshaaeqaaaaa@39D7@
ρ
P
v
e
n
t
aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AC8@
u
v
e
n
t
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyDamaaBa
aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AED@
and
A
v
e
n
t
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaBa
aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AB9@
(8)
m
o u t
ρ
v e n t
A
v e n t
⋅ u = ρ
P
e x t
P
1
γ
A
v e n t
⋅ u
YnaaBaaaleaacaWG2bGaamyzaiaad6gacaWG0baabeaakiabgwSixl
aadgeadaWgaaWcbaGaamODaiaadwgacaWGUbGaamiDaaqabaGccqGH
flY1caWG1bGaeyypa0JaeqyWdi3aaeWaaeaadaWcaaqaaiaadcfada
WgaaWcbaGaamyzaiaadIhacaWG0baabeaaaOqaaiaadcfaaaaacaGL
OaGaayzkaaWaaWbaaSqabeaadaWcaaqaaiaaigdaaeaacqaHZoWzaa
aaaOGaeyyXICTaamyqamaaBaaaleaacaWG2bGaamyzaiaad6gacaWG
0baabeaakiabgwSixlaadwhaaaa@61C2@
In the case of supersonic outlet flow, the vent pressure,
P
v
e
n
t
is equal to external pressure,
P
e
x
t
for unshocked flow. For shocked flow,
P
v
e
n
t
is equal to critical pressure,
P
c
r
i
t
aaleaacaWGJbGaamOCaiaadMgacaWG0baabeaaaaa@3ABD@
and velocity,
u
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyDaaaa@36F0@
is bounded to critical sound speed:
(9)
u
2
2
γ + 1
c
2
2 γ
γ + 1
P
ρ
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG1bWaaW
baaSqabeaacaaIYaaaaOGaeyipaWZaaSaaaeaacaaIYaaabaGaeq4S
dCMaey4kaSIaaGymaaaacaWGJbWaaWbaaSqabeaacaaIYaaaaOGaey
ypa0ZaaSaaaeaacaaIYaGaeq4SdCgabaGaeq4SdCMaey4kaSIaaGym
aaaadaWcaaqaaiaadcfaaeaacqaHbpGCaaaaaa@489D@
and
(10)
P
c
r
i
t
P
2
γ
1
γ
γ
1
(11)
P
v
e
n
t
max
P
c
r
i
t
P
e
x
t
The outgoing mass flow of gas
i
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@
is:
(12)
m
o u t
i
V
i
V
m
o u t
aadaWgaaWcbaGaam4BaiaadwhacaWG0baabeaakmaaCaaaleqabaWa
aeWaaeaacaWGPbaacaGLOaGaayzkaaaaaOGaeyypa0ZaaSaaaeaaca
WGwbWaaWbaaSqabeaadaqadaqaaiaadMgaaiaawIcacaGLPaaaaaaa
keaacaWGwbaaaiqad2gagaGaamaaBaaaleaacaWGVbGaamyDaiaads
haaeqaaaaa@46AD@
Where,
V
i
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaCa
aaleqabaGaaiikaiaadMgacaGGPaaaaaaa@3945@
is the volume occupied by gas
i
and satisfies:
(13)
V
i
n
i
n
V
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGwbWaaW
baaSqabeaadaqadaqaaiaadMgaaiaawIcacaGLPaaaaaGccqGH9aqp
daWcaaqaaiaad6gadaahaaWcbeqaamaabmaabaGaamyAaaGaayjkai
aawMcaaaaaaOqaaiaad6gaaaGaamOvaaaa@406D@
from
P
V
i
n
i
R
T
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbGaam
OvamaaCaaaleqabaWaaeWaaeaacaWGPbaacaGLOaGaayzkaaaaaOGa
eyypa0JaamOBamaaCaaaleqabaWaaeWaaeaacaWGPbaacaGLOaGaay
zkaaaaaOGaamOuaiaadsfaaaa@4114@
and
P
V
i
n
i
R
T
Ovaiabg2da9maadmaabaWaaabuaeaacaWGUbWaaWbaaSqabeaadaqa
daqaaiaadMgaaiaawIcacaGLPaaaaaaabaGaamyAaaqab0GaeyyeIu
oaaOGaay5waiaaw2faaiaadkfacaWGubaaaa@435E@
Then,
(14)
m
o
u
t
i
n
i
i
n
i
m
o
u
t
WGUbWaaWbaaSqabeaadaqadaqaaiaadMgaaiaawIcacaGLPaaaaaaa
keaadaaeqbqaaiaad6gadaahaaWcbeqaamaabmaabaGaamyAaaGaay
jkaiaawMcaaaaaaeaacaWGPbaabeqdcqGHris5aaaakiqad2gagaGa
amaaBaaaleaacaWGVbGaamyDaiaadshaaeqaaaaa@4C91@
Porosity
The isenthalpic model is also used for porosity. In this case, you can define the
surface for outgoing flow:
(15)
A
e f f
C
p s
⋅ A r e
a
p s
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS
baaSqaaiaadwgacaWGMbGaamOzaaqabaGccqGH9aqpcaWGdbWaaSba
aSqaaiaadchacaWGZbaabeaakiabgwSixlaadgeacaWGYbGaamyzai
aadggadaWgaaWcbaGaamiCaiaadohaaeqaaaaa@45FC@
or,
(16)
A
e f f
C
p s
( t ) ⋅
Area
p s
( P −
P
e x t
baaSqaaiaadwgacaWGMbGaamOzaaqabaGccqGH9aqpciGGdbWaaSba
aSqaaiaadchacaWGZbaabeaakiaacIcacaWG0bGaaiykaiabgwSixl
GacgeacaGGYbGaaiyzaiaacggadaWgaaWcbaGaamiCaiaadohaaeqa
aOGaaiikaiaadcfacqGHsislcaWGqbWaaSbaaSqaaiaadwgacaWG4b
GaamiDaaqabaGccaGGPaaaaa@4F5D@
Where,
C
p s
( t )
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGdbWaaS
baaSqaaiaadchacaWGZbaabeaakiaacIcacaWG0bGaaiykaaaa@3B9D@
Function of
fct_ID cps
Area
p s
( P −
P
e x t
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGbbGaai
OCaiaacwgacaGGHbWaaSbaaSqaaiaadchacaWGZbaabeaakiaacIca
qaaOGaaiykaaaa@4313@
Function of
fct_ID aps
It is also possible to define closure of the porous surface when contacts occurs by
defining the interface option I bag =1 .
