/@TFILE
Engine Keyword The time at which the time history file begins.
/@TFILE
Tstart ΔTsampling
N1 N2 ... NN
Definition
Tstart Time at which the time history file begins to be written.
ΔTsampling Time frequency to write data on file.
N1 , N2 ... NN List of nodes.
  1. The name of the time history file is "Runname_0001@.thy".
  2. Only nodal velocities are saved in the file.
  3. When restarted if you specify the @TFILE parameters again (Tstart, ΔTsampling , list of nodes and the variables), the filtering is reinitialized and this may result in a non-contiguous TFILE. For a clean restart, just specify /TFILE without any parameters at all.
