/TFILE
Engine Keyword Defines the frequency of writing the time history file of T-file "RunnameTnn".
/TFILE/Type
Δ T h i s MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaamiAaiaadMgacaWGZbaabeaaaaa@3AE8@
Definition
Type No value: Built-in format of current Radioss version.
= 1
Binary (not readable by most Radioss post-processors)
= 2
Coded ASCII 32-bit
= 3
ASCII
= 4 (Default)
Binary IEEE 32-bit
Δ T h i s MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaamiAaiaadMgacaWGZbaabeaaaaa@3AE8@ Time frequency to write data on history plot file T-file.
  1. Recommended options are default (no value) or four, which can be read by HyperGraph.
  2. This file contains the global results (energy, global mass, momentum) and all the time history requests defined with the keyword /TH/….
  3. Additional time history file can be generated with the keywords /ATFILE to /ITFILE for the specific requests defined using the keywords /ATH to /ITH.
  4. See "File Extensions and Formats" for details on T-file name.
