/ATFILE
Engine Keyword Defines the frequency of writing additional time history file of T-file "RunnameTnna" from specific request defined with the corresponding keyword /ATH.
Nine different time history files can be generated with the keyword from
/ATFILE to /ITFILE:
| Starter Keyword | Engine Keyword | Time History File |
| /ATH | /ATFILE | RunnameTnna |
| /BTH | /BTFILE | RunnameTnnb |
| /CTH | /CTFILE | RunnameTnnc |
| /DTH | /DTFILE | RunnameTnnd |
| /ETH | /ETFILE | RunnameTnne |
| /FTH | /FTFILE | RunnameTnnf |
| /GTH | /GTFILE | RunnameTnng |
| /HTH | /HTFILE | RunnameTnnh |
| /ITH | /ITFILE | RunnameTnni |
/ATFILE/Type
Definition
| Type | Output format.
| Time frequency to write data on history plot file T-file. |
- Recommended options are default (no value) or four, which can be read by HyperGraph.
- These additional time history files do not contain the global results (energy, global mass, momentum).
- Each time history file has its own time output frequency.
- See File Extensions and Formats for details of T-file name.
