OS-V: 0060 Thick Plate Pressure
Test No. LE10 The model is a thick plate subjected to uniform normal pressure of 1 MPa on the upper surface of the plate. OptiStruct examines the direct stress at the point D for linear static analysis.
![](../../../images/solvers/nafems_thick_plate_pressure.png)
Model Files
Before you begin, copy the file(s) used in this problem
to your working directory.
Benchmark Model
Second order Hexahedral, Penta and Tetra elements are used to create the coarse and fine mesh. A uniform pressure of 1 MPa is applied on the upper surface of the plate.
The material properties are:
- Material Properties
- Value
- Young's Modulus
- 210 x 103 MPa
- Poisson's Ratio
- 0.3
Linear Static Analysis Results
All results are normalized with the target value (5.38 MPa).
Direct Stress at Point D (MPa) | Normalized with the Target Value | |
Solid Hexahedral: | ||
Hex20 coarse | 5.32 | 1.011278195 |
Hex20 fine | 5.58 | 0.964157706 |
Solid Wedges: | ||
Penta15 coarse | 5.9484.91 | 1.10557620895723014 |
Penta15 fine | 5.94 | 0.905723906 |
Solid Tetrahedral: | ||
Tetra10 coarse | 5.741 | 0.937118969 |
Tetra10 fine | 5.029 | 1.069795188 |
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
