Create a Material
Create, modify, apply, save, and organize materials.
From the view controls at the bottom left of the modeling window, select Display Modes, and then select Performance Render or Quality Render.
  1. Select one or more objects.
  2. On the Rendering tab, select the Editors tool.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
    The Render Editor appears.
  3. Select the Material tab.
  4. From the Shader dropdown menu, select a material type.
    • None
    • Plastic
    • Carbon Fiber
    • Metal
    • Leather
    • Wood
    • Simple Glass
    • Glass/Gems
    • Fabric
    • Paint
    • Construction
    • Emitter
    The material is applied.
  5. Define the parameters.
Plastic Material Parameters
Define the color, reflectivity, roughness, transparency, and more.
Color
To define the color, choose from the following options:
  • Select a color.
  • Select a texture. The texture overrides the color.
  • To blend the color with the texture, click the plus symbol (+). You can tell if the blend option is turned on by looking at the image preview.
To define the shade, enter a value of 0-100, where 100 is the true color and 0 is black.
Reflectivity
Define the strength of the reflections.
Enter a value of 0-100, where 100 produces perfect mirror reflections and 0 produces the weakest reflections.
Roughness
Roughness adds texture to the material at a microscopic level. When you modify the roughness, the surface texture still looks the same; however, tiny changes invisible to the naked eye have occurred, affecting reflectivity.
0 can produce a perfect mirror reflection.
Lower values produce crisper and brighter reflections.
Higher values produce blurrier, dimmer reflections. Increasing the roughness spreads and distributes reflections over the surface and creates a more matte surface.
At values approaching 100, light becomes so scattered that reflections are barely visible, if at all.
Note: Roughness and Reflectivity are interdependent properties; smoother surfaces produce crisper reflections, while rougher surfaces produce blurrier reflections. For example, set roughness to 0 and reflectivity to 100 to produce a perfect mirror reflection. To make the reflection blurrier, increase the roughness.
Transparency
Define the level of the material transparency. 100 = completely transparent, 0 = fully opaque.
Bump
Bump adds texture to the material at a macroscopic level. Because it visibly affects the surface texture, Bump is useful for simulating irregular surfaces.
A bump map gives the illusion of texture without physically distorting the geometry, minimizing rendering time. The grayscale map tells Inspire Form how to change the surface normals as if the surface had been displaced; the modified normals are used in lighting calculations. A bump map looks like the inverse of what you might expect: black represents the highest extreme and white represents the flattest extreme, while shades of gray represent grades in between.
Coating
Create varnishes and paints on a layered material.
The coating will reflect some light, while the rest of the light will be absorbed by the layer of material underneath; the extent to which this happens affects how the final material looks.
Several coatings may be applied one after the other, simulating multiple varnishes and paints.
Figure 1. Plastic without a Coating
Figure 2. Plastic with a Coating
Scratches
Add scratches to a material.
Wear
Add wear to a material.
Trimming
Add cut-out patterns to a material.
Carbon Fiber Material Parameters
Reflectivity
Roughness
Transparency
Texture
Select or upload a texture to apply to the object. To learn how to adjust the texture, see Edit and Position the Material's Texture.
Color
  • Select a color.
Bump
Anisotropy
Stretch and blur highlights. Anisotropic reflections are like regular reflections, except they are stretched and blurred against the grain of the material. They are often used to simulate finely brushed metals.
Coating
Figure 3. Plastic without a Coating
Figure 4. Plastic with a Coating
Scratches
Wear
Trimming
Metal Material Parameters
Presets
The Preset is automatically set to Custom.
Choose one of the following options:
  • Aluminum
  • Brass
  • Chassis
  • Chromium
  • Copper
  • Galvanized
  • Gold
  • Silver
  • Stainless
  • Titanium
Color
  • Select a color.
Reflectivity
Roughness
Transparency
Bump
Coating
Figure 5. Plastic without a Coating
Figure 6. Plastic with a Coating
Brushed
Add a brushed finish to a material.
Scratches
Wear
Trimming
Leather Material Parameters
Reflectivity
Roughness
Transparency
Texture
Bump
Coating
Figure 7. Plastic without a Coating
Figure 8. Plastic with a Coating
Scratches
Wear
Trimming
Wood Material Parameters
Reflectivity
Roughness
Transparency
Texture
Bump
Coating
Figure 9. Plastic without a Coating
Figure 10. Plastic with a Coating
Scratches
Wear
Trimming
Simple Glass Parameters
Color
  • Select a color.
Reflectivity
Roughness
Transparency
Texture
Bump
Coating
Figure 11. Plastic without a Coating
Figure 12. Plastic with a Coating
Scratches
Wear
Trimming
Glass/Gems Parameters
Create solid glass objects, glass vessels containing liquid, and gemstones.
Roughness
To add a roughness map, upload an image.
Presets
  • Amethyst
  • Aquamarine
  • Diamond
  • Emerald
  • Fluorite
  • Glass
  • Plastic
  • Polycarbonate
  • Quartz
  • Ruby
  • Sapphire
  • Topaz
  • Water
  • Zircon
  • Custom
Figure 18. Example of Glass
Absorption Color
Define which colors of the spectrum are absorbed (thus not visible) by uploading an image or picking a plain color. The remaining colors of the spectrum are reflected (thus visible).
Absorption Distance
Lower values are more transparent. Higher values are more opaque. Values range from 0 to 0.05 m.
Index of Refraction (N)
Define the reflectivity of the surface. Higher values correspond to more intense reflections.
If you selected a preset, this value is predefined. If you selected a custom preset, look up the index of refraction online.
Use Abbe Number
Abbe Number: Lower values correspond to a stronger rainbow effect. Increase the value to make the effect more subtle. The default value is 10.
Fabric Material Parameters
Reflectivity
Roughness
Transparency
Texture
Bump
Coating
Figure 29. Plastic without a Coating
Figure 30. Plastic with a Coating
Scratches
Wear
Trimming
Paint Material Parameters
Color
  • Select a color.
Glow Color
Define the color of the glow.
Glow Intensity
Define how intensely the metallic flakes glow. Increase this value for a brighter glow; decrease it for a softer glow. We suggest keeping this value under 30-35%, as increasing this number too much can obliterate the base color.
Roughness
Transparency
Coating
Figure 31. Plastic without a Coating
Figure 32. Plastic with a Coating
Scratches
Wear
Trimming
Construction Material Parameters
Reflectivity
Roughness
Transparency
Texture
Bump
Coating
Figure 33. Plastic without a Coating
Figure 34. Plastic with a Coating
Scratches
Wear
Trimming
Emitter Parameters
Define the color, power unit, and side.
Note: It is recommended to set Display Mode to Quality Render.
Color
Define the color of the light by choosing a plain color from the color palette. It is recommended to use subtle, light colors for better results.
Power Unit
The default is Watts. Switch to Lumens to automatically convert the Power value.
Power
Enter a value between 0 and 150 Watts or between 0 and 22500 Lumens.
Side
Select which side of the object to emit from. The default option is Both.
After you apply a material with a texture to one or more objects, you can edit, scale, and position the texture.
Warning: Some types of materials don't include the texture parameter, such as Plastic, Metal, and Paint.
  1. Next to Texture, select the texture preview image.
    The Textures dialog box is displayed.
  2. Select the texture you would like to apply to the material.
  3. Edit, reposition, or scale the texture.
    To Do this
    Colorize the texture
    1. Next to the texture preview image, select .
    2. From the context menu, select Colorize Texture.
      The Color dialog box is displayed.
    3. Choose the color you would like to apply to the material, then click OK.
    Adjust the texture's parameters
    2. From the context menu, select Edit Image.
      A dialog box is displayed, with texture parameters.
    3. Adjust the following parameters:
      • Invert: Invert all the colors of the texture to their complementary colors.
      • Gamma
        Default value: 2.2. Lower values will make the image darker while higher values will give a washed-out look.
        Gamma correction is important if you want to display an image accurately on a computer monitor. It controls the overall brightness, as well as the ratios of red to green to blue, of an image. Without proper gamma correction, the image can look bleached out or too dark.
      • Saturation: Use a value from -100% to 100%.
      • Brightness
        Use a value from ‐100% to 100% to control the tone of the texture. A brightness of ‐100% makes the image completely black.
      • Contrast
        Higher values will give higher contrast.
      • Clamp min (%) and Clamp max (%): Specify the minimum and maximum clamp of the selected texture. RGB colors normally range from 0 to 255. By setting, for example, the minimum clamp to 20%, the colors with RGB values less than around 51 will be “cut” and get this value. By increasing minimum clamp percentage, the image turns whiter, while decreasing the maximum clamp percentage results in darker image colors. By decreasing the maximum percentage and increasing the minimum at the same time, textures tend to appear grayer, as gray colors has RGV values around the middle of the 256 colors (128, 128, 128).
    Remove the current texture
    2. From the context menu, select Remove.
    Open the texture library
    2. From the context menu, select Library.
    Scale the texture
    2. From the context menu, select Position Texture.
      The Control Panel is displayed.
    3. Enter values for the following:
      • Global Size
      • Size X
      • Size Y
      • Size Z
    Define the aspect ratio
    3. Enter the Aspect Ratio.
    Position the texture
    3. Turn on Flip Horizontally or Flip Vertically.
      You can also position the texture using the manipulator that appears in the modeling window when you open the texture positioning settings.
    1. Drag the handles of the manipulator to move the texture to the optimal position. Any settings you adjust using the manipulator are reflected in the corresponding Control Panel values.
    2. Click the green check mark in the Control Panel to apply your edits.
    Revert the texture to undo the last edit
    3. The Control Panel is displayed.
    4. Click the Revert button.
    Reset the texture to the default settings
    4. Click the Reset button.
  4. Right-click and mouse through the check mark to exit, or double-right-click.
