Importing and Merging Geometry
Use to import and merge a saved model with the current model.
- Select or press Ctrl+I.
- In the Import File dialog, select a file. You can filter by file type and show previous versions of models.
- Click Open.
Tip:
- The imported model is inserted as an assembly under the top-level folder in the Model Browser. To move the imported model within the model hierarchy, drag the folder in the Model Browser.
