Design
Type of shaft
The design of the machine can be considered with or without a shaft. Hence, two solutions are proposed:
  • None: The shaft is not represented and not considered in the rotor design. It is replaced by fluid (like air).
  • With shaft: The shaft is represented and considered in the rotor design.
Note: The shaft can be built only with solid material.
Table 1. Type of shaft
Shaft type: None Shaft type: Solid
Table 2. Type of shaft
The dimensions are illustrated with arrows. The connection side (C.S.) is identified by yellow lightning.
Inputs – Validity domain
  • C.S. diameter (D1) - Connection side end-shaft diameter:]0, 20000] mm
  • C.S. extension (L1) - Connection side end-shaft extension:]0, 20000] mm
  • O.C.S. diameter (D2) - Opposite connection side end-shaft diameter:]0, 20000] mm
  • O.C.S. extension (L2) - Opposite connection side end-shaft extension:]0, 20000] mm
