Bearing
Introduction
Once the shaft is selected, the section of Bearing is unlocked, meaning that it is
possible to access the bearing settings. There are two possible choices:
- None: No dimension to declare. There is no bearing.
- With bearings: Bearings characteristics must be defined - Structural data of bearings are then edited.
Remember: Once the housing is designed, the
selection of both Shaft design and Bearing is mandatory for accessing the
internal cooling topology design area.
Type of bearing
Note: When the machine is designed with bearings, they are
represented and considered in the rotor design. See the different configurations
below.
| Shaft-Bearing type: None | Shaft-Bearing type: With bearings |
Input parameters – Validity domain
The user inputs dedicated to the definition of bearings are illustrated below.
| 1 | Bearing length |
| 2 | Bearing width |
| 3 | Bearing shift |
- C.S. length - Connection side bearing length:]0, 20000] mm
- C.S. width - Connection side bearing width:]0, 20000] mm
- C.S. shift - Connection side bearing shift:]0, 20000] mm
- O.C.S. length - Opposite Connection side bearing length:]0, 20000] mm
- O.C.S. width - Opposite Connection side bearing width:]0, 20000] mm
- O.C.S. shift - Opposite Connection side bearing shift:]0, 20000] mm
