Cooling
Introduction
Once the shaft is selected, the section of Cooling is unlocked meaning that it is
possible to access shaft-cooling settings. There are three possible choices:
- Solid: No shaft-cooling design. Shaft remains as previously defined in Design.
- Cooling - Hollow: A hollow shaft-cooling must be defined, and the input parameter becomes editable.
- Cooling – Ring: A ring shaft-cooling must be defined, and the input parameters become editable.
Types of shaft-cooling
Note: When the machine is designed with shaft-cooling, it is
represented and considered in the rotor design and thermal design of the machine.
See the different configurations below.
| Shaft-Cooling type: None | Shaft-Cooling type: Hollow |
| Shaft-Cooling type: Ring | Dimensions are illustrated with arrows |
Connection side (C.S.) is identified by yellow lighting.
Input parameters – Cooling - Hollow
The user input dedicated to the definition of hollow shaft-cooling is illustrated below.
| 1 | Hollow shaft diameter |
- Hollow shaft diameter – Inner diameter of hollow shaft:]0, 20000] mmNote: Even though the diameter limits are the default ones, the hollow shaft diameter is constrained by the lowest shaft diameter set in the Design section (C.S diameter or O.C.S. diameter).
Input parameters – Cooling - Ring
The user inputs dedicated to the definition of bearings are illustrated below.
| 1 | Ring inner diameter |
| 2 | Ring outer diameter |
- Ring inner diameter:]0, 20000] mm
- Ring outer diameter:]0, 20000] mm
Note: Even though the diameters limits are the default ones, the
ring shaft diameters are constrained by the lowest shaft diameter set in the Design
section (C.S diameter or O.C.S. diameter). Also, the ring inner diameter cannot be
set equal to the ring outer diameter, as expected.
