Steady State AC Magnetic: solved equations (scalar model)
Introduction
The scalar model is a general model proposed for 3D applications.
This model is used by default (automatically) by Flux to solve 3D applications.
Magneto Static: reminder
As previously presented for Magneto Static applications, various potentials can be introduced to solve the system of equations. Flux 3D has different magnetic formulations using different scalar potentials. There is a formulation and consequently an equation for each region of the problem.
The formulations introduced for the Magneto Static application are:
- formulation in total scalar magnetic potential, ϕtot,
- formulation in reduced scalar magnetic potential with respect to Hj, ϕredHj
- formulation in reduced scalar magnetic potential with respect to T0, ϕredTo
… in Steady state AC Magnetic
Within the Steady state AC Magnetic application, other formulations are introduced to treat the conducting (magnetic or not) media with possible eddy currents.
These formulations are not described in this document.
