List of temporary files
Here is a list of the locations for temporary files:
%CD% (Flux working directory)
  • %CD%\*.log or %CD%\*.report
    Flux log files.
    Note: They can be deleted if Flux is not running.
  • %CD%\hs_err_pid[0-9]+
    Contains diagnostic errors if the application crashes.
%APPDATA% (Windows 10 -> C:\Users\<userid>\AppData\Roaming ) or $HOME (Linux)
  • %APPDATA%\flux\fsg_setting (Not Applicable to Linux)
    Configuration used by Flux Supervisor Starting Guide.
    Warning: Do not delete unless Flux has been uninstalled.
  • %APPDATA%\flux\hostfile.txt ($HOME/.flux/hostfile.txt on Linux)
    Configuration used by Flux MUMPS solver.
  • %APPDATA%\flux_starting_guide (Not Applicable to Linux)
    Configuration used by Flux Supervisor.
  • %APPDATA%\.EMachineToolbox\<version> ($HOME instead of %APPDATA% on Linux)
    Cache and log files.
    Note: They can be deleted if the application is not running. They will be recreated as needed when the application starts.
  • %APPDATA%\.matmanager\<version> ($HOME instead of %APPDATA% on Linux)
User %TMP% (Windows 10 -> C:\Users\<userid>\AppData\Local\Temp) or $TMP or /tmp (Linux)
  • %TMP%\jffi[0-9]+.dll (Not Applicable to Linux)
    Temporary Jython DLLs for running Flux.
    Note:
    • They can be deleted if not in use by Flux.
    • (No automatic deletion for now this is a known Jython issue).
  • %TMP%\[0-9]+ ($TMP or defaults to /tmp on Linux)
    Temporary folders for Anonymous projects.
    Note:
    • They should be automatically deleted when the Anonymous project is saved or closed.
    • They may be deleted if Flux is not running.
  • %TMP%\FLUX_* ($TMP or defaults to /tmp on Linux)
    Temporary files used when Flux is running ("Undo", "Linear solving" ...).
    The following environment variables may be used instead of TMP if they are defined in the user environment: TMPDIR or DLOGTMP or TEMP.
System %TMP% (Windows 10 -> C:\Windows\Temp)
  • %TMP%\jna[0-9]+ (Not Applicable to Linux)
    Folder that contains jna DLLs.
