Post-processing quantities: rotation motion
Introduction
This paragraph deals with physical quantities computed for rotating motion .
Kinematic variables
The list of kinematic variables used for solving and the names of the corresponding Flux parameters are given in the table below; in this table MS indicates the concerned mechanical set.
Kinematic variable Name Unit
Angular position: AngPos(MS) degree
Angular speed: AngSpeed(MS) degree/s
Angular acceleration: AngAcc(MS) degree/s²
Physical quantities
The list of physical quantities computed in the post-processing module and the names of the corresponding Flux parameters are given in the table below; in this table MS indicates the concerned mechanical set.
Torque Name Unit Explanation
Electromagnetic torque: TorqueElecMag(MS) N.m
Internal system
Friction torque: TorqueFrInt(MS) N.m
Spring return torque: TorqueSpInt(MS) N.m
Inertia torque: TorqueInInt(MS) N.m
Resistant torque*: TorqueReInt(MS) N.m or
External system
Friction torque: TorqueFrExt(MS) N.m
Spring return torque: TorqueSpExt(MS) N.m
Inertia torque: TorqueInExt(MS) N.m
Resistant torque *: TorqueReExt(MS) N.m or
Note: * The resistant torque is:
  • either the sum of the friction torque + the spring return torque
  • or the resistant torque defined using a formula
Reminder of the solved mechanical equation
The solved mechanical equation for rotating motion is:
where:
  • J is the moment of inertia:
  • is the moment of inertia of the moving mechanical set itself (internal system)
  • is the moment of inertia of the external load (external system)
  • is the electromagnetic torque
  • is the resistant torque:
  • is the resistant torque acting on the moving mechanical set (internal system)
  • is the resistant torque acting on the external load (external system)
Important note
When there are symmetries or periodicities, the computed values of the torque correspond to the entire device.
