Definition of regions for an incomplete computation
Introduction
The simplified or incomplete computation is a computation carried out under the following conditions:
  • the computation is accomplished without taking into account of the current density in the structure
  • the structure introduced in the electrolyte is represented by means of boundary conditions
Volume region
Volume regions are gathered in the table below.
A volume region…
is a material region which enables the modeling…
electrolytic conducting of a conducting medium (resistivity ρ)
inactive of an insulating medium
Face region
Face regions are gathered in the table below.
A face region… is a BC that enables one to impose…
electrochemical interface
conditions at the interface “electrolyte – cathode” by the intermediate of a polarization law
imposed potential
a potential (varying formula / spatial formula) (sacrificial anode)
imposed normal current density
a normal current density* (varying formula / spatial formula) (active anode)
Note: * The normal is directed from the face region towards the electrolyte.
Line region
Line regions are gathered in the table below.
A line region … is a BC that enables one to impose …
imposed potential
a radial current density* (varying formula / spatial formula) (active anode)
Note: * The normal is directed from the line region towards the electrolyte.
Point region
Point regions are gathered in the table below.
A point region… is a BC that enables one to impose…
imposed potential a potential in a point
