Cut geometric objects
Cut a geometric object
To cut a geometric object:
Step Action
1
Open the dialog box:
  • click on the icon: or
  • in the Tools menu, click on Cut geometric objects
The dialog box Select cut plane is opened.
2
To cut one or several geometric objects:
  • select the object(s) to cut
  • select the cut plane to be used
3
Confirm: by clicking on
Cutting sheets are created at the places where the objects can be cut.
The dialog box Select cutting sheets is opened.
4
To continue the cutting of the geometric object(s):
  • select the desired cutting sheets
  • choose a name for the objects that will be created after the cutting
5
Confirm by clicking on OK
The new objects are created as a result of the cutting.
