Previewing the 3D geometry and creating sensors in Flux Skew before solving
A new special function for Flux Skew module that enables the pre-visualization of the skewed 3D geometry and the creation of sensors before solving a scenario.
Introduction
- Verify that the 3D skewed geometry generated by the extrusion performed by Flux Skew and the corresponding physical description are correct.
- Create sensors before solving the actual users' scenarios. In Flux Skew, this procedure allows a faster evaluation of the sensors when compared with evaluating sensors created after solving.
Where to find this special function
In Flux Skew module and for all applications while in pre-processing the Create preview 3D command can be accessed through the Solving menu as depicted in Figure 1.
At a second step a pop up window prompts for a project name (Figure 2). The user may choose a new name for that project or overwrite it by providing the current project name.
At this point, Flux Skew will build a scenario called PREVIEW3D, which becomes automatically active (Figure 3). The user can then explore the skewed design in 3D and eventually create sensors.
Allowed post-processing actions within the PREVIEW3D scenario
The most important actions that are allowed in the PREVIEW3D scenario are summarized in Table 1 below. The availability of the same actions in the regular 2D context of Flux Skew (before solving) and in a proper scenario (after solving) are also shown in that table, for the sake of comparison.
| Context in Flux Skew | |||
| Possible actions | 2D view (before solving) | PREVIEW3D scenario | Regular solved scenario |
| Create sensors |
| Change 2D geometry and physics | |||
| Check skewed geometry | |||
| Create new scenario | |||
Transitioning between the pre-processing (2D view), preview 3D and post-processing contexts (Regular solved scenario) of a project in Flux Skew
Figure 4 below illustrates the different states of a Flux Skew project and the actions required to transit between them.
