Flux e-Machine Toolbox improvements
FEMT 2022.1 improvements
- Switch from User to Dynamic numerical memory mode and vice versa inside FeMT
- Distributed computing available on Linux
- Run tests through PBS (by manual Export / Import)
- New extrapolation approach for efficiency maps
- Either switching from User numerical memory mode to Dynamic numerical memory mode by setting the Numerical Memory (MiB) to 0
- Or switching from Dynamic numerical memory mode to
User numerical memory mode by setting the
Numerical Memory (MiB) to a fixed amount of memoryWarning: When switching from Dynamic numerical memory mode to User numerical memory mode, the user must know the numerical memory required to solve the project and therefore set a high enough value.
On Linux, it is now possible to run a test by activating the local distribution.
First, you have to make sure that the distribution is properly configured.
See Parametric distribution in Flux (Linux) for more information.
To save computation time, it is now possible to run tests through PBS.
- In FeMT: Export the required files for PBS
- In PBS: Run the computation through a cluster
- In FeMT: Import the results from PBS
And then postprocess the results as usual.
There is now a new map extrapolation method to obtain correct values near map borders and thus avoid obtaining non-physical values, such as negative Irms values.
