Altair Feko Release Notes
This guide covers changes to recent versions of Altair Feko.
View Altair Feko Comprehensive Release Notes online for release notes from previous versions.
Altair Feko 2023.1 is available with an assortment of new features, corrections and improvements. Altair Feko 2023.1 is a major release. It can be installed alongside other instances of Altair Feko.
Altair Feko 2023.0.2 is available with new features, corrections and improvements. This version (2023.0.2) is a patch release that should be applied to an existing 2023 installation.
Altair Feko 2023.0.1 is available with new features, corrections and improvements. This version (2023.0.1) is a patch release that should be applied to an existing 2023 installation.
Altair Feko 2023 is available with new features, corrections and improvements. Altair Feko 2023 is a major release. It can be installed alongside other instances of Altair Feko.
Altair Feko 2022.3.2 is available with new features, corrections and improvements. This version (2022.3.2) is a patch release that should be applied to an existing 2022 or 2022.3 installation.
Altair Feko 2022.3.1 is available with new features, corrections and improvements. This version (2022.3.1) is a patch release that should be applied to an existing 2022 or 2022.3 installation.
Altair Feko 2022.3 is available with new features, corrections and improvements. It can be applied as an upgrade to an existing 2022.2 installation, or it can be installed without first installing Altair Feko 2022.2.
Altair Feko 2022.2.2 is available with new features, corrections and improvements. This version (2022.2.2) is a patch release that should be applied to an existing 2022 or 2022.2 installation.
Altair Feko 2022.2.1 is available with new features, corrections and improvements. This version (2022.2.1) is a patch release that should be applied to an existing 2022 or 2022.1 installation.
Altair Feko 2022.2 is available with new features, corrections and improvements. It can be applied as an upgrade to an existing 2022.1 installation, or it can be installed without first installing Altair Feko 2022.1.
Altair Feko 2022.1.3 is available with new features, corrections and improvements. This version (2022.1.3) is a patch release that should be applied to an existing 2022 or 2022.1 installation.
Altair Feko 2022.1.2 is available with new features, corrections and improvements. This version (2022.1.2) is a patch release that should be applied to an existing 2022 or 2022.1 installation.
Altair Feko 2022.1.1 is available with new features, corrections and improvements. This version (2022.1.1) is a patch release that should be applied to an existing 2022 or 2022.1 installation.
Altair Feko 2022.1 is available with new features, corrections and improvements. It can be applied as an upgrade to an existing 2022 installation, or it can be installed without first installing Altair Feko 2022.
Altair Feko 2022.0.2 is available with new features, corrections and improvements. This version (2022.0.2) is a patch release that should be applied to an existing 2022 installation.
Altair Feko 2022.0.1 is available with new features, corrections and improvements. This version (2022.0.1) is a patch release that should be applied to an existing 2022 installation.
Altair Feko 2022 is available with new features, corrections and improvements. Altair Feko 2022 is a major release. It can be installed alongside other instances of Altair Feko.
