Importing Array Parameters From File
Specify a file to import an array with a user-defined distribution, or to import an irregular-spaced array or both.
![](../../../../images/feko/lua_scripts/script_array_tool/dialog_import_values_from_file.png)
In the Filename field, browse for the file you want to
import. The number of antenna array elements is determined from the specified
file.
Note:
- If you have selected Custom array in Step
5, the file that you import must contain the X, Y and Z
coordinates, amplitude, and phase (in degrees).
For example (if you use comma-separated values):
20, 30, 40, 1, 0 25, 30, 40, 2, 20 28, 30, 40, 5, 30
- If you have selected Custom (import from
file) in Step 1, the file that you import must contain the magnitude, and
phase (in degrees), where the base element is the last element in
the file.
Figure 2 illustrates the element order when importing the magnitude and phase from a file.1, 0 2, 20 5, 30
Figure 2. An example showing the element order for a 3x2 planar antenna array where the magnitude and phase are imported from a file. The base element is the last element specified in the file.
Under Delimiter, select the delimiter type used in the
file to be imported from the following list:
- Comma
- Tab
- Space
- Click OK to close the dialog.
![](../../../../images/feko/lua_scripts/script_array_tool/image_array_custom.png)
