Viewing the Near Fields
Display the calculated near fields in the 3D view. Animate the instantaneous near field.
- Select the 3D View1 window.
Enable mesh opacity to view the near field inside the waveguide.
On the 3D View contextual tabs set, on the Mesh tab, in the Opacity group, click the
Mesh opacity
icon. From the drop-down list, select a value of
40%.
On the Home tab, in the
Add results group, click the
Near Fields icon. From the drop-down list, select
NearField1.
Animate the phase of the near field.
- In the result palette, in the Quantity panel, select Instantaneous magnitude.
On the 3D View
contextual tabs set, on the Animate tab, on the
Settings group, click the
icon. From the drop-down list, select the
Phase
icon.
Start the animation process.
On the 3D View
Control group, click the
Play
icon.
Stop the animation by clicking the
Play icon again.
On the 3D View
