Viewing the Input Reflection Coefficient
Plot the input reflection coefficient on a Cartesian graph in dB.
Create a new Cartesian graph.
On the Home tab, in the
Create new display group, click the
Cartesian icon.
Add the input reflection coefficient to the Cartesian graph.
Add results group, click the
Source data icon. From the drop-down list, select WaveguideSource1.
View the input reflection coefficient in dB.
- On the result palette, in the Traces panel, select WaveguideSource1.
- On the Quantity panel, select the dB check box.
Change the legend position to top-right.
On the Display tab, in the
Display group, click the
Position icon. From the drop-down list select Overlay top right.
Remove the graph footer.
Chart text icon.
- In the Graph footer field, clear the Auto check box and delete the text.
- Click OK to apply the text changes and to close the dialog.
[Optional] Add annotations to the graph.
On the Cartesian
context tab, on the Measure tab, on the Custom annotations group, click the
Points icon. From the drop-down list, click
Global maximum.
Note: The power reflected back to Port1 is more than 30 dB lower than the power applied to the same port. -
On the Cartesian
