Viewing the Input Reflection Coefficient
View the input reflection coefficient on a Cartesian graph in dB.
On the Home tab, in the
Create new display group, click the
Cartesian icon.
Add results group, click the
Source data icon. From the drop-down list, select
VoltageSource1.
View the input reflection coefficient in dB versus frequency.
- On the result palette, in the Traces panel, select VoltageSource1.
- On the Quantity panel, confirm that Reflection coefficient is selected (default option).
- On the Quantity panel, select the dB check box.
Figure 1. The result palette containing the Traces, Source, Slice and Quantity panels (listed from top to bottom).
Change the legend position to bottom-right.
On the Display tab, in the
Legend group, click the
Position icon. From the drop-down list select Overlay
bottom right.
Remove the graph footer.
Display group, click the
Chart text
icon.
- In the Graph footer field, clear the Auto check box and delete the text.
- Click OK to apply the text changes and to close the dialog.
Figure 2. The input reflection coefficient in dB versus frequency.
