Defining Calculation Requests
Define the calculation requests in CADFEKO.
Create a S-parameters request.
- Delete StandardConfiguration1.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Calculate the S-parameters of a simple microstrip notch filter. Use different solvers and compare the results.
Model the microstrip filter using the finite element method. Use a FEM modal port for the source.
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Run the Solver to compute the calculation requests.
Model the microstrip filter using the surface equivalence principle. Use a voltage source on an edge port for the source.
Model the microstrip filter using an infinite substrate and planar multilayer Green's function. Use a voltage source on a microstrip port for the source.
View and post-process the results in POSTFEKO.
Calculate the transmission and reflection for a stepped waveguide transition from the Ku- to X-band. Use two solver methods, the method of moments (utilising waveguide ports) and the finite element method (utilising FEM modal ports).
Match a short dipole for resonance at 1.4 GHz with an LC matching section. The matched network is modelled using a Spice circuit and S-parameters.
Calculate the input impedance of a circularly polarised patch antenna fed through a microstrip branch coupler. Replace the branch coupler with a non-radiating network and compare with a full solution.
Calculate the S-parameters (coupling) of a four port microstrip coupler. Use the finite difference time domain (FDTD).
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
