Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Set the model unit to millimetres.
Define the following variables.
- fmin = 1.3e9 (The lowest simulation frequency.)
- fmax = 1.5e9 (The highest simulation frequency.)
- h = 70 (The height of the dipole.)
- wireRadius = 0.1 (The radius of the dipole segments.)
Create the dipole.
- Set a continuous frequency range from fmin to fmax.
Create a general network using a SPICE circuit.
Create a voltage source.
- For Port select MatchingNetwork.Port1
In the schematic view, connect Port1 (the dipole) to Port2 of the
network.
Figure 1. Schematic view of the matching network and port of the dipole.
