Creating the Monopole and Ground Plane
Create a monopole antenna and infinite PEC ground plane.
Define the following variables:
- fmin = 1e6 (The minimum frequency.)
- fmax = 35e6 (The maximum frequency.)
- wireRadius = 1e-3 (The wire radius of the monopole.)
Create the monopole.
- Add a wire port (segment) to the base of the line.
- Add a voltage source to the port. (1 V, 0°, 50 Ω).
- Set the total source power (no mismatch) to 10 W.
- Add an infinite PEC ground plane.
