Viewing the Results
View and post-process the results in POSTFEKO.
The resource requirements (time and memory) for the MLFMM solution are notably smaller than for the full MoM solution. Some solution times from the .out file are given below. Note that times are strongly dependent on the hardware.
SUMMARY OF REQUIRED TIMES IN SECONDS
CPU-time runtime
Reading and constructing the geometry 1.630 1.631
Calcul. of the MLFMM transfer function 0.876 0.876
Fourier transform of MLFMM basis funct. 4.505 4.508
Calcul. of matrix elements 126.248 126.251
Calcul. of right-hand side vector 0.099 0.099
Preconditioning system of linear eqns. 44.603 44.603
Solution of the system of linear eqns. 112.489 112.486
total times: 293.942 293.941
(total times in hours: 0.082 0.082)
Specified CPU-times are referring to the master process only
Sum of the CPU-times of all processes: 2351.498 seconds ( 0.653 hours)
On average per process: 293.937 seconds ( 0.082 hours)
Peak memory usage during the whole solution: 443.363 MByte
For the antennas mounted on the helicopter:
- View the coupling between the antennas as a function of frequency on a Cartesian graph.
Figure 1. The antenna coupling as a function of frequency on a Cartesian graph.
View the reflection coefficients of the antennas as a function of frequency on
a Cartesian graph.
Figure 2. The reflection coefficients of the antennas as a function of frequency on a Cartesian graph.
