Offset/Shell
Use the Shell tool to remove the cage face and create thin walls to generate a shelled PolyNURBS part.
On the PolyNURBS ribbon, select the Shell tool.
- Left-click to select faces to remove from the PolyNURBS part. Hold the Ctrl key to add or remove faces from the selection.
- Enter the desired thickness of the shell in the microdialog.
- Click Apply to create a preview of the shelled PolyNURBS part.
- Click Apply to accept the preview and create the shelled PolyNURBS part.
- Double right-click to exit the tool.
