2026
Learn to use Inspire Cast with our interactive tutorials.
Discover new features and enhancements.
New to Inspire Cast? Learn the basics here.
Tutorial Level: Beginner Run a simulation of a gravity casting adjusting different components to see the effects on the results.
Tutorial Level: Beginner Step through setup and defining the rotation for a gravity tilt pouring casting simulation.
Tutorial Level: Beginner Set up a high pressure die casting simulation and see how to troubleshoot it.
Tutorial Level: Beginner Learn how to simulate a stalk and set up a pressure curve for a low pressure die casting simulation.
Tutorial Level: Intermediate See the difference in porosity of a solid model and the same model with a core.
Tutorial Level: Intermediate See how the two halves of a reflectionally symmetric part solidify when a chiller is added to one side.
Tutorial Level: Intermediate Compare the solidification in a riser with that of risers with isothermal and exothermal sleeves.
Tutorial Level: Intermediate Observe how a cooler helps maintain a homogeneous temperature range throughout a mold, particularly in high pressure die casting.
Create 2D sketches, surfaces, and solids with construction history and variables.
Designate and analyze casting parts, set gravity direction and mold opening direction, define runner system, and configure casting components.
Run a casting analysis to minimize defects and prevent manufacturing problems.
Download the Casting Benchmark Manual to learn more about benchmark and verification tests.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Got questions? We have answers!
