Tutorial: Adding a Core Component
Tutorial Level: Intermediate See the difference in porosity of a solid model and the same model with a core.
In this exercise, you will learn how to analyze the effect a sand core has on casting.
Import Geometry
Before you begin, copy the file(s) used in this tutorial to your working directory.
  1. From the menu bar, select File > Open.
  2. Browse to your working directory, select core.x_b, and click Open.
    The model opens in the modeling window.
Designate a Casting Part
Select casting geometries with the Cast Part tool.
Important: A cast part must be defined before performing any other operation.
  1. On the Cast Part icon, click Designate Casting Part.
  2. Left-click to select which candidate is a cast part.
    Parts are automatically detected and highlighted based on your cursor position.
    The selected part is highlighted red.
  3. In the microdialog, select Steel as the material and select 1,4903 as the alloy for the part.
  4. Right-click and mouse through the check mark to exit, or double-right-click.
Set Gravity Direction
  1. On the Cast Part tool, click Set Gravity Direction.
  2. Click the Gravity icon in the microdialog to align gravity to the normal of a selected surface.
  3. Click one of the bottom surfaces of the part.
    Gravity will automatically be realigned perpendicular to the selected surface.
Add a Gate
  1. On the Gate icon, click Add/Edit Gate.
  2. Create two gates: select a surface of the model to place a gate there, and enter the dimensions in the microdialog as shown below.
Add a Core
  1. Click the Components tool.
    Click the Core tool in the secondary tool group.
  2. Cavities that can become cores are shown in gray. Click to select which candidate is a core and automatically create the core volume.
  3. In the microdialog, select Silica-Sand as the material.
Run Analysis
  1. On the Analysis icon, click Run Analysis.
  2. In the Run Analysis dialog, select the Stages tab and enter the Element size manually or define the Average Thickness. You can also select number of cycles in the process by selecting Use cycling.
  3. Select the Advanced tab to manually select mesh factors for components like gate, mold, runner, riser, etc.
  4. Select the Stages tab and click Run.
    Note: The mold will automatically generate when you click Run.
    Note: Once the simulation calculation is finished, a green flag will appear on the analyze icon.
Analyze Results
  1. Click the green flag on the Analyze tool.
    You can also select the run and click View Now in the Run Status window.
  2. Click Solid Fraction under Result Types.
  3. Set the Solid Fraction percentage to 0.70.
    Note: The solid fraction value is set to 0.7 by default. In most cases, this corresponds to the value at which the liquid stops flowing.
  4. Click Play to start the animation.
    In the animation, solidified material (above 0.7) is transparent, while liquid material (below 0.7) is shown colored. Shrinkage porosity is more likely to occur in isolated areas.
  5. Click Demolding under Stage and click Porosity under Result Types.
  6. Set the percentage to 100%.
    There are no regions of 100% porosity in the finished part.
