Create an Appliance
Create an appliance by selecting an application, cloud provider, region for hosting the appliance, and configure the cluster.
Altair Appliances supports Altair Drive storage for accessing user files.
The process of creating an appliance is as follows:
  • Select an appliance model, to create an appliance.
  • Provide a name for the appliance.
  • Select an application (batch or interactive) from the list. You can choose one or more applications from the list.
  • Set the application arguments and the its values.
  • Select the cloud provider from the list.
  • Select the region for hosting the appliance.
  • Configure the cluster by selecting the nodes and other details for the cluster.
  • Create and deploy the appliance.
  1. Launch Altair NavOps.
    The list of appliances is displayed.
    Figure 1. Appliances
    Appliances
    The list displays the Appliance Name, Status, Cloud Provider, Uptime (number of days the appliance is up and running), License Units, and Node status and resources consumption.
    Note: Click to change the column list of the Nodes table.
  2. Click Create new appliance on the top to create a new appliance.
    The appliance models are displayed.
    Figure 2. Appliance Models
    The information about the model is provided with its version and tags.
    Click Detail to view more information about the model.
  3. Click Select to view the appliance model details.
    Figure 3. Appliance Model Details
  4. Click in My appliance and enter a name for the appliance.
    Figure 4. Appliance Name
  5. Click Please select one to select an application from the list.
    Figure 5. Add Application
    The list of batch and interactive applications is listed.
    Choose one or multiple applications from the list.
    Tip: Interactive application (Altair NavOps) information is displayed below the application icon.
  6. Click Add.
    Figure 6. Add an Application
    The application is added and displayed in the Applications section.
    Figure 7. Add Applications
    Add Applications
    Note: Click to remove the application from the application table.
  7. Click Select a cloud infrastructure to view the registered cloud infrastructures.
    Figure 8. Cloud Infrastructure
  8. Choose one of the following cloud infrastructure:
    • Altair managed cloud account such as AWS, Azure, and GCP. Select the required account to configure.
    • Your own cloud accounts registered in Altair NavOps to configure.
    Figure 9. Add Cloud Infrastructure
  9. Select a geographical region for your cloud infrastructure.
    Figure 10. Select Region
    Select Region
    Tip: Select the region for your cloud infrastructure using the Region list.
    The number of Altair Units required by the appliance is displayed.
  10. Click to configure the cluster.
    Figure 11. Add Cluster
    Add Cluster
    The list of instances available in the cloud for the selected application is displayed.
    Figure 12. List of Instances for the Application
    The list displays the Instance name and its hardware configuration such as CPU Cores, RAM, and GPU Cores.
  11. Select an Instance.
    Figure 13. Cluster Instance Type
    Tip: You can choose multiple cluster configuration for an application.
  12. Click Parameters at the top to configure the cluster parameters and its values.
    Select Undeploy on error to undeploy the appliance when there is an error during the deployment.
    Based on the configuration, the total number Altair Units is displayed.
  13. Click Create.
    Figure 14. Create an Appliance
    Create an Appliance
    The appliance instance is created.
    Figure 15. Create and Deploy an Appliance
  14. Choose one of the following options:
    • Click Create to create an appliance and deploy it at a later time.
      Note: This only creates an appliance and does not start the appliance.
    • Click Create and Deploy to automatically deploy the appliance after creation.
    • Click Cancel to modify the appliance details.
    The new appliance is displayed in the Appliances list.
    Figure 16. Updated Appliance List
    Appliance List
    A series of notifications are displayed providing the information about deploying the appliance and scripts running to create the cluster.
    Note: You can also click to view the notifications and the steps that are performed.
Now you can Start an Appliance.
