Events
Events main function is to monitor the changes that cause a change in a Thing's property by providing a log of all these changes emitted from the real-world entity.
Events are defined similarly to Properties and Actions. They allow for several metadata keys to describe what the event is, and those metadata keys follow a standard format.
The following keys can be used to describe an event:
Metadata Definition | Description | Required? | Type |
title |
Title of the Event | No | string |
description |
Additional content to tell the user what the event is for. | No | string |
data |
Defines the expected format of the event body. | No | object |
data
key. The data key is
what stores the information that describes what each event should look like. The
information expected in an event (as defined in the data key of the Thing
description) can be any one of the following primitive types:array
- Expects a list of results
boolean
- Expects a true/false
number
- Expects any real number
integer
- Expects any whole number
object
- Expects a JSON object with additional properties defined.
string
- Expects a series of letters and/or numbers
null
- Expects no value
Each of these primitive types can be further defined by any or all of the following metadata keys.
title |
Title of the event data displayed in the UI. | No | string |
description |
Additional content to tell the user what the event data is for. | No | string |
type |
Primitive data type for validation of the event data. | No | string |
unit |
Provides a reference unit, especially for numbers and integers. | No | string |
readOnly |
Validates that a value should not be written to. | Yes (default is false ) |
boolean |
minimum |
Minimum value. Used for validation. | No | number |
maximum |
Maximum value. Used for validation. | No | number |
minimum |
Minimum value. Used for validation. | No | integer |
maximum |
Maximum value. Used for validation. | No | integer |
