Move a Folder or a File
Move a folder or a file from one location to another within a server.
Tip: You can also use Cut and Paste option to move a folder or a file
from one location to another.
- Click the Files tab located in the upper left-hand of the page.
- Using the file system tree on the left, navigate to the location where you want to move the folder or a file.
Select the folder or a file that you want to move.
Tip: You can select multiple folder or a file to move. Select the first folder or a file by clicking its name and hold down CTRL and select each folder or a file by clicking its name.
Figure 1. Move Folder or a File
Drag the selected file to the destination.
Figure 2. Move Folder or a File to Destination
Tip: You can also move the folder in the file system tree on the left by dragging the folder from one location to another.
