Prerequisites
- Login to the machine where Access Web is installed as root or as a user with sudo permissions.
                Source the Access Web configuration file to set up the
                    environment variables PA_HOME and
                        PA_EXEC:
source /etc/pbsworks-pa.conf
                Edit the ODIC configuration file.
vi $PA_HOME/config/oidc/config.yaml
                Uncomment the line passwordConnector: ssh.
oauth2: skipApprovalScreen: true passwordConnector: ssh
                Restart Access Web for these changes to take effect by
                    entering the following command:
systemctl restart pbsworks-pa
