Getting Started
Access client package provides connect() function to connect to
                    Access Web server and returns AccessClient
                object. Using submit_job() method of AccessClient,
                a job can be submitted and returned Job object can be used to
                perform operations on that job.
An example of the client
                code:
            import access.client as access_client
with access_client.connect("https://23centos7:4443", "david") as client:
    job_input = {"CORES":"1","MEMORY":"1","EXECUTION_PLATFORM":"linux","PRIMARY_FILE":"/stage/david/generate_data.py", "FILES":"","CHUNKS":"1","CHUNK_PLACEMENT":"pack","MEMORY_PLACEMENT":"true","JOB_NAME":"Generate Data","SUBMISSION_DIRECTORY":"/stage/david/generate_data"}
    # NOTE: User has to provide password in the prompt
    #     Enter password for user 'david': ········
    job_obj = client.submit_job("ShellScript", job_input)
    print(job_obj)
    # Get current job status
    job_status = job_obj.status()
    # Wait till job is finished
    job_obj.wait()
    # Download any job file
    data_file_path = job_obj.download_file("data.csv")
    print(open(data_file_path).read())
    # Remove job from WLM
    job_obj.delete()
    # Delete all job files downloaded using 'download_file' API
    job_obj.clean()Methods chaining is supported on job
                object:
client = access_client.connect("https://23centos7:4443", "david")
data_file_path = client.submit_job("ShellScript", job_input) \
                       .wait() \
# Close client explicitly as it is not opened using 'with' statement
client.close()
