Node Selection
To select nodes in the set viewer you have the following methods:
        - Draw a rubber band around the nodes you want to select by clicking and dragging the left button.
- Hover over a node and click on the node to select.
- Hover over a node and type 's' to add it to the group of selected nodes.
- Type m to select every node with a similar status to any of the statuses in the current set of selected nodes.
- Press Ctrl-a to select all nodes in the viewer.
- Press Ctrl-i to invert the selection.
- Press Ctrl-c to clear the selection.
- Type / to activate the quick-search capability. Enter some other characters in the quick-search bar, then press Enter to select the nodes you have found.
